I recently had a new combi condensing boiler installed by corgi reg. installer- radiators not replaced. Heating & water worked fine. After a couple of weeks I noticed the water did not heat up - I checked boiler & saw reset button flashing so reset system. Problem kept recurring - water heated when radiators on but not when rads. off. I then noticed that gas supply to cooker was diminshed when rads. switched on. Installer came to check problem but could find no fault with system or installation. His meter readings showed dramatic drop in gas pressure when rads. on. He said this was causing cooker to lose gas supply & boiler probs. He suggested that as no fault found with boiler system, the problem must be with the gas meter & therefore I must contact my gas supplier as he is unable to carry out work on the meter.
Can anyone tell me if this sounds correct - It seems a coincidence that the gas meter should be faulty just after having new boiler installed - or maybe this is the reason why my old boiler was ineffective in heating water as I never had the gas pressure checked before (never noticed a problem with the cooker before though)
Any advice welcome[/b]
