I am not an RGI so take it easy but i am interested in knowing what does gas rating an appliance tell us about that appliance can anyone tell me please?
Gas rating is a procedure used to measure the volume of gas consumed by an appliance in a set period of time. Using the reading taken at the meter you can then determine if the appliance is using the same amount as it was designed to.
This is a simple test which is often overlooked but very important. The maximum kilowattage of a boiler can be checked and confirmed. Add a combustion check and you know it's using the right amount of gas safely.
Over or under gassing an appliance is dangerous.
good for fault finding too ie a combi not giving hot enough water. If it's using the right amount and a good flame picture it must be something mechanical. Plate heat exchanger, diverter valve, pump etc IMO.
