Gas rating appliance
12 Nov 2009
I am not an RGI so take it easy but i am interested in knowing what does gas rating an appliance tell us about that appliance can anyone tell me please?
Gas rating is a procedure used to measure the volume of gas consumed by an appliance in a set period of time. Using the reading taken at the meter you can then determine if the appliance is using the same amount as it was designed to.
HTH Sam
This is a simple test which is often overlooked but very important. The maximum kilowattage of a boiler can be checked and confirmed. Add a combustion check and you know it's using the right amount of gas safely.
Over or under gassing an appliance is dangerous.
good for fault finding too ie a combi not giving hot enough water. If it's using the right amount and a good flame picture it must be something mechanical. Plate heat exchanger, diverter valve, pump etc IMO.
Its primarily a measure of the power input to the appliance.
Knowing its efficiency then enables the power output to be found.
Or, depending on what can be measured, the efficiency can be deduced.
Its used for routine checks the boiler is set up correctly, eg on landlord checks and also for more complicated fault finding.
