- Joined
- 2 Oct 2010
- Messages
- 3,624
- Reaction score
- 667
- Country
we read it the 1st time.
we read it the 1st time.![]()
Sorry, appears to be some fault with the site as keeps repeating my posts, sorry!!
No I think its on for 9 hours but I've also got it set to 15/16 overnight so it's less heat but its another 5 hours on occasional firing? Plus we obviously both shower once a day on top of this and my hot water is timed on for two hours in the morning and from 5pm all evening. I really don't have many rads, the overall BTU is 26500 not sure what the conversion to kW is but its not a lot! I realise its an old house and its got two layer unfilled cavity walls (but does have 200mm loft insulation) but this seems far too high still. Not sure what to do??
Agreed. If any of the rads are receiving too much flow and not dissipating that excess heat then the return temp is going to be unnecessarily high. This will reduce efficiency, not only through being less able to condense but also due to the inevitable additional cycling if it cannot modulate low enough.It may be that your central heating system needs balancing also.
How was it done? What were the temps and drops?Oh yes and the system was definitely balanced
