GATEVALVE VS STOPCOCK:
31 Mar 2009
Surrey
Whilst people are good enough to answer my silly questions, can I ask another!! Do gatevalves totally stop water flow or does a little still dribble through? I know a working stopcock is 100% - isn't it better to use these on the outlets from the loft tank, they surely don't impede flow too much?
Working gate valves shut off fully.
Stop taps dramaticaly decrease flow rate due to there design. Whereas gatevalves are full bore (same as the pipe size) when fully open - hence, not restricting any flow at all. Which is why they are used ;)
Another option would be a full bore iso valve, or full bore lever valve ;)
Not all gate valves are full bore, the cheap ones i picked up from plumbcenter the other day were only about 13mm through the centre and that was on the 28mm gatevalve. i took it back and swapped it for a pegler.
That'll be because plumb centres own gate valves dont conform to the bs.
Plunb-centre should be given a swift kick up the derriere for selling sub-standard fittings. Many DIYers wouldn't spot this.
