Vaillant turboMax combi boiler Stopcock
6 Oct 2005
London
Hi All,
New on here!
Reason for my question is because I am trying to stop a leaking hot water stopcock tap to the washing machine, but it is boiler related!
The hot "outflow pipe" from my boiler leads directly to the hotwater tap for the washing machine, via a 'T-junction' joint. To change the leaking tap, I obviously need to stop the hot water flow from the boiler. However there is no stopcock on the pipe leading into the boiler, so I am at a slight loss as to how to turn off the hot water flow?
Any bright ideas anyone? Feel free to ask any questions about something I might not have described well enough.
Jock
Either turn off the cold mains to the house, or find the cold mains isolator on the inlet to the boiler and turn this off. Either will stop the DHW.
Hi Kevplumb,
It definitely isn't underneath the boiler - I've followed the pipe up into the boiler and there is no means of stoping the flow.......
Jock
there is no means of stopping the flow
Yes there is, it's just that you don't recognise it. Just turn off the mains cold water - much simpler.
kevplumb said:
gray knob :wink:
Sounds like you need a doctor if that's the case.
Also kev, is that your dog eared tax return stuffed into the fascia of your boiler along with the user instructions?
Hi All,
thanks for the replies.
I presume that once I have turned off the mains and repaired both the taps, the system will need re-pressurising - or have I got the wrong end of the stick. i,e will messing around with one of the outflow pipes have little impact on the pressurised system for central heating etc?
cheers again
Jock
