I have a geberit duofix system with a double plate. About a year ago the small button of the flushing plate stopped working (it flushes if there is water in the cistern but it does not refill) and a plumber adjusted the mechanism inside and it worked again fine till now. I am having the same problem again. The small button does not work the first time you push the button (the tank does not refil with water)but usually does if I push it a second time.
I would be extremely grateful if someone could tell me how I can remove the plate and adjust the system.
Many thanks.
Many thanks.
