Hi guys - looking for a few bits of info - i'll breifly explain
I'll be installing my own system shortly - obviously with a corgi/gassafe checkover+gas hook up......Mainly because the quotes i've had are stupid, owing to owning a cast concrete house, but not wanting any pipes showing. I know where the pipes need to go, but every guy thats been out to look at it has said " I'd just run the pipe along the skirting. Thats the easy option - But it uses nearly double the pipe, looks CRAP, and means running tracks into a concrete floor.....I'd make a better job of it myself, as i can take my time, and run the pipes where i want them.....I
Radiators - Works out most of the rooms need anywhere between 2700btu, and 3300 btu...For that reason, i'll be using 600x600 K2 radiators throughout - with the exeption of the living room ( dang mrs wants a fancy vertical rad ) TRV's all round
Boiler - it'll be upstairs, in a bathroom cupboard - Mounted directly to a concrete wall, horiz. flue. Good location for pipework in my house, its where the mains cold water appears, and where all the junctions are made for hot and cold water for all locations ( sensible place for a boiler IMO) I'll be fitting a magnaclean too.
Pipework - 1m copper from boiler - 22mm to 15mm barrier for hot water, T'd ( one to downstairs, one to upstairs) again, 22mm to 15mm barrier for heating, t'd downstairs and upstairs..
So, my questions........
What boilers are the pro's fitting at the moment - i'll be looking somewhere around the 30kw mark...i Im not OVERLEY concerned about it being A rated, as there is only 2 of us, and i'd have to weigh up the extra energy used in a b rated boiler against the extra cost of a A rated boiler.
i've seen some boilers that fit the bill at £400...But REALLY - seems a tad cheap to be decent quality !
Where is a good place to buy cheap rads/TRV/Locksheilds.......looks like 5 radiators ATM. Prefer online - HEATING PACK ???
Also, which is the prefered make of plastic pipe - and fittings. "speedfit" seems to me like the most availible to me locally.
Lastly, i'll take any advice that you guys might have !
