Getting Zs down
22 Dec 2004
Hi On a circuit with a type c mcb wired in 10 mm t&e cable to get the Zs down for the type c when calculating I can use a 10 mm cpc. Is it permissable to use the 4mm in the t&e with an additional 6mm ?? or will I have to run in a seperate 10mm cable.
views please
thanks
os
can't see why not, supplementry CPCs are used with big SWA runs all the time.
You can supplement, but if you are putting an additional one in, I would as a rule, ignore the one in the cable (still connect it).
