I'm wondering if someone can help with this problem as it's really annoying.
Boiler works fine for hot water no problem.
On the heating side, it's got the wireless room-stat, which works well, with the timer elements.
i.e. at 1630 the boiler turns on and promptly does it's best to get the room to 19c for instance.
Once it's got there, it stops going at full whack....
BUT...
Every 60 seconds or so, it gets to the point where it realises it's warm enough, and doesn't need gas etc, and turns off (well it goes quiet), I presume it's the pump/fan stopping.
5 seconds later, it changes it's mind, powers up, 4 flames of gas usage, heats up for 10seconds, then does the process again. This continues until the timer tells it to turn off.
It's obviously not right, but am not sure what is causing it.
Any help/advice please.
It's NOT the wireless room stat, have tried a different one, and the problem remains.
BUT...
