Gloss or Semi Gloss / Satin Wood for a wooden banister?
11 Oct 2021
Hi all... I'm decorating the hall...
Have keyed back the old gloss on the banister, and applied a new coat of Dulux Pro Liquid Gloss, but ended up with a lot of tiny bubbles in the finish, which felt horrible when you ran your hand down it.
So, I sanded back to the wood (two days) and have now done a test patch: two coats of Zinsser B-I-N Shellac Primer, and one of Dulux Pro Liquid Gloss. But I can see before the gloss is dry that it has some bubbles / imperfections in it.
No idea what product the decorator originally used to get such a good finish, but should I be using something other than Dulux Pro Liquid Gloss for this? Am I better off with a satin wood?
Any help and insight is always appreciated.
The Zinsser B-I-N Shellac Primer was recommended to me by a shop employee who suggested it would help cover a multitude of sins.
How did you apply it? Bubbles typically are a result of using a roller, but that would be surprising for a banister.
The paint is oil-based, right?
Applied with a Harris multi paint brush, no roller in sight.
Yes, the gloss is oil-based.
Just done another test patch with three lots of undercoat... I'm starting to wonder if the bubbles aren't dirt / fibres from the wood... I've fine sanded it and cleaned / wiped it to within an inch of it's life though...
Just pine I'm afraid. It's probably about three or four years old.
Just some thoughts that may or may not help. Is the paint old. Has it been well mixed? Have you used anything oily or greasy, white spirit, brush cleaner?
Sorry gents, new tins of both Zinsser B-I-N Shellac Primer and Dulux Pro Liquid Gloss, new brushes, and washed with the advised solutions; methylated spirits and turps...
I wonder if I need to give the brushes longer to dry out after washing before I use them again to reapply?
I would make sure the brushes are really dry. I always wash brushes in warm water and washing up liquid after cleaning to remove any residue. 24 hours should do it, I usually wrap the bristles in some kitchen towel to help maintain the shape.
