I have a Glow Worm Compact 75e, over the past couple of weeks we have been experiencing a problem where when the hot water taps or shower is turned on, the boiler doesn't always ignite to heat the water. The indicator light next to the tap symbol on the boiler comes on to show that it is sensing the water flow however the boiler ignition doesn't come on. I had a plumber around yesterday to look at this problem and he fitted a new 'diaphram' (small rubber disc) inside the part with the pin controlling the domestic hot water micro switch as he thought this had worn and was causing the problem. However this is still occuring. The system has been bled and the pressure checked. The heating part seems to be operating normally.
I wonder if I replaced the domestic hot water switch with the replacement one with three cables whether this would solve my problem?
Can anyone help please? I noticed namsag had commented on a post a number of years ago for a Glow Worm Compact 100e.
Thank you!
It's just been suggested by Glow Worm support that it could be the thermistor? Would this cause an intermittent problem or would I simply never get hot water?
Thank you!
