Glow worm micron boiler
9 May 2010
Hertfordshire
the heating worked on friday night but stoped yesterday. The boiler will only stay alight for just over 70 seconds. Any ideas??
I can not understand why the hot water is still working? I have had a new radiator fitted but that worked on Friday night (first time it was used) :?
Many thanks
Yep.
motorised valve faulty?
pump faulty?
blocked cold feed?
dry header tank?
pipework blockage?
boiler fault?
roomstat fault?
Hope that helps.
David.
The Microns are notorious for dodgy pcb`s, sometimes if you open up the boiler and lift the pcb they fire up ok! I wouldn`t recommend doing it yourself though.If your pcb board is green glowworm have upgraded them and they are now brown because of the recurring fault, or it might be other way round, haven`t done one fer yonks.
Many thanks
Why did you not state this in your original post, and added it about 6 hours later?
Its totally relevent to the topic :roll:
David.
