    Dismiss Notice
Glow-Worm Ultimate2 30C and the Hive Receiver wiring.
Discussion in 'Plumbing and Central Heating' started by Billbo45, 1 Dec 2020.
  1. Billbo45
    Billbo45
    1 Dec 2020
    2
    Thanks Received:
    Country:
    Hi all
    I have a Glow-Worm Ultimate 30c combi boiler and there are only two wires to the room thermostat.
    I am about to wire in a Hive Receiver which shows it needs four wires.
    I am pretty sure the existing wires are simply for ON/OFF and use 24v.
    And the Receiver needs 240v to power it.
    Am I right in assuming that the wires to the Receiver are as follows...
    N- Permanent 240v Neutral connection.
    L- Permanent 240v Live Connection.
    1- Common, unused.
    2- Heating OFF so one of the two existing wires from the existing thermostat.
    3- Heating ON the remaining of the two existing wires from the existing thermostat.
    Or... are terminal 1, the common and terminal 3, heating ON the two I use for the existing thermostat wires?
    Any help would be appreciated.
  2. stem
    stem
    20 Jul 2005
    6,463
    Thanks Received:
    1,472
    Nottinghamshire
    Country:
    Second guess is correct. (y) You want 'common' and 'heating on' as the thermostat switch wires. Terminals 1 and 3.
    The heating off terminal becomes live when the heating erm... goes off so you won't want that!
  3. Sponsored Links
  4. Billbo45
    Billbo45
    1 Dec 2020
    2
    Thanks Received:
    Country:
    Thanks Stem.
    Ill let you know how it goes tomorrow.
  5. ianmcd
    ianmcd
    15 Aug 2010
    19,654
    Thanks Received:
    7,652
    Lanarkshire
    Country:
    Do not link L&1 as advised in some other posts ,you dont need it and if you do actually have 24v switching you will damage the boiler PCB
  6. Sponsored Links
Loading...
Share This Page
