Grants Combi 90 V3 - not firing up help!
12 Dec 2014
Invernesshire
Hi needing urgent help no heating or hot water.
Boiler was working fine then stopped - went to check pressure had dropped to just above zero. No amber lockout illuminated.
Repressurised to 1 bar.
Pump running fine boiler still not firing.
Got someone to look at it checked power to burner with Meter not showing any voltage thinks may be PCB - am not so sure.
Can anyone give me any pointers - had snow for 3 days.
99% chance the temperature PCB is goosed! try turning off the mains electrical supply for a few seconds and then on again - you may find the burner will fire (until the PCB freezes again!!) very common fault on this model boiler :wink:
