Gravel drive - drainage ?
4 May 2012
Nottinghamshire
Hi all,
I am planning a new gravel driveway this spring.
Whoever did it previously seems to have just laid gravel on the existing soil.
Anyway, I am getting the lot dug out before 150mm of type1 is whacked down.
A questions first.
The Drive slopes towards the house very very slightly. What, how and when is drainage installed, if needed at all ?
obviously with block paving or tarmac you install a drain running to existing drains! I am confused with the gravel as to how the rain water gets in to the drain ‍♂️
Cheers all
you must lay permiable to drain into the soil not the drains to comply with regs
unless the soil isnt sutable
