green gunge coming from the Megaflo
doitall said:
Softus said:
2. Brass compression couplings on copper pipe;
dry joint no doubt :lol:
Not a laughing matter - the leak reached the flat below, where a retired gent lived, and he was quite upset by it.
And no - invariably the joints weren't dry. On one of them (inside a Gledhill cabinet) the cause was exactly the reason why I detest jointing compound - the f***ing stuff was partly on the threads, making it difficult for the incompetent installer to tighten up to the correct torque.
FFS. Jointing compound. I ask you. Why not use wattle and daub? :roll:
gas4you said:
I've seen 'o' rings with what looks like little 'nicks' in them. I generally think that they are so mass produced that you will get a certain amount of failures. How can they quality control all 'o' rings etc :roll:
I partly agree, which is why I:
(a) check every push-fit fitting by eye, before installing, to make that it has no missing or clearly damaged parts;
(b) disassemble every Hep2o fitting that I'm making onto copper tube, because otherwise the end of the tube can nick the 'O' ring;
(c) never use a Speedfit fitting onto copper where the joint is out of view, because they're harder/slower to disassemble; if I'm forced into doing it, then it has to be brand new copper cut with a brand new cutting wheel on a pipeclice.
