    Dismiss Notice
Green star i24
Discussion in 'Plumbing and Central Heating' started by fattony, 2 May 2020.
  1. fattony
    fattony
    1 May 2006
    914
    Thanks Received:
    Country:
    Hi
    I have a Greenstar i24 boiler which I noticed had the reset light flashing, the pressure was on 0 - it’s in the loft so I hadn’t noticed it.
    I filled it back up and pressed reset for 3 seconds, it tries to fire up but it locks out again
    Any ideas or do I need someone out?
    thanks
  2. Chris_W
    Chris_W
    26 Sep 2019
    5,042
    Thanks Received:
    1,380
    North
    Country:
    It may have overheated, try it again today.
  3. Sponsored Links
  4. martyndc88
    martyndc88
    26 Apr 2009
    895
    Thanks Received:
    183
    South Glamorgan
    Country:
    Need a little more info to help you out. Does the blue light flash as well? And in what sequence?
    How long does it try and fire back up for before going to lockout ? Does it try and light up five times?
    Check you have gas, and that the handle on the meter hasn't been knocked to the off position
  5. fattony
    fattony
    1 May 2006
    914
    Thanks Received:
    Country:
    Thanks, had someone out in the end, apparently it’s the gas valve, makes sense, yes the blue light is flashing as well, it tries to fire up but just cuts out again
  6. Sponsored Links
  7. martyndc88
    martyndc88
    26 Apr 2009
    895
    Thanks Received:
    183
    South Glamorgan
    Country:
    Surprised at that, gas valves on these are pretty bullet proof. Hope it get sorted quick enough
  8. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
