Grill element replacement
You say its deformed? That'll be the ring that doesn't work and will not glow hot when the grill is switched on.
Is the grill element brand new or a used part?
It has been suggested by others that elements do absorb moisture in storage and could explain your symptoms. You could try drying it out and testing it again in the cooker.
Its a long shot but worth exploring to eliminate as a possibility.
When I say deformed, it has drooped on one front corner, like it's overheated at some point. The old element has been on there since the oven was new about 12 years. The new one is brand new from AEG.
The old one works fine, I was only replacing it, because it had dropped at the corner, but I will check the resistance like you said and see if there is any difference.
Cheers
As 'Yardie' has said there may be a fault elsewhere, that element staying on all the time may be because it is being used as part of the 2nd oven element so the t/stat may have failed.
Does the 2nd oven work correctly?
