In reality I've not grouted much over the years, however the times I have I've never had any issues.
Until now.
I'm using this stuff: https://www.diy.com/departments/nx-...VX5NQBh0t3g6lEAQYAiABEgKAo_D_BwE&gclsrc=aw.ds
tbh I've not yet started grouting the main area, I'm tinkering around some edges and small alcove bits. I'm applying the grout, ensuring it's well pressed into the joint, then wiping away the excess. At that point the gap I've filled looks fine, however over the next 10-15 mins, the majority of the grout seems to disappear, almost like quite extreme shrinkage. Or maybe some sort of suction effect drawing it behind the tile? So I then need to redo the same gap and even then, although it'll do, you still see it going a bit concave.
I wondered if I'm maybe working on the grout too quickly i.e. should I be leaving it another few mins before wiping away excess and tidying the filled gap?
I'm now concerned that when I do the main larger surface, I'll have to do it a second time due to this issue.
Is it something I'm doing wrong, or is it not a great grout?
Until now.
