he Grundfos pump plan saga goes on.
July 2016 Worcester Bosch Greenstar boilers wiring guide shows the pump plan for 2 pump systems on pages 13, 25 and 61 so anyone with a 2 pump system buying one of those boilers will find that Grundfos no longer make the wiring centre. So you end up with a boiler that no one knows how to wire in so that the pump over-run works!
If I'm wrong and someone can tell me - then shall be eternally grateful as have a new Ri 24kw on the wall and can't trigger the over-run without some wiring / relay info!
If you have a Grundfos pump plan, you will still have the wiring centre, because they were supplied together.
If you have a heating system with two Grundfos pumps (far more common) you need an installer who understands electrics. That should be any boiler installer; but the reality is many are combi bashers and bathroom installers who haven't the knowledge...
NB: Warranty is invalid on the boiler with no pump overrrun.
