what is the difference in grundfos pumps can a 15-60 replace a 15-50x 18 which is unatainable..
Can I just say, I've probably spent the last 2+ hours trying to work out what those number mean.replace with a selectric 15-50 (direct swap) or an ALPHA2/2L 15-50 whitch is also a direct swap but more economical, a better pump and of course much more expensive
the numbers refer to bore size (15) and head the pump produces (50= 5 metres) BTW
Thanks John I'm looking at the 8M as we've had a loft extension done, and from the pump/boiler to the top of the highest radiator is around 7mYou shouldn't need a 8M (80) pump replacing a 5M or 6M pump but most 5/6M pumps are 130mm port to port.
I've got another thread open specifically about the pump replacement, this was more the meaning around the numbers.I don't know how much the pump head required (in metres) depends on the actual physical height of your system. I think it's more to do with the resistance in the system. I think the pressure to push the water to high radiators comes from the pressure vessel, more than the pump. Hopefully, somebody else will weigh in to say where the balance lies.
That is correct.I think you said on the other post that the radiators in the living room don't get hot?
