first of all, can I ask that anyone who skim reads this, and immediatly goes "I know what that is" doesn't give the answer away immediatly
Anyway, this morning I went to do a domestic PIR, background is that homeowner had experienced some issues with RCD protection for the sockets tripping and had been recommended a PIR to see what issues lie within. In the short term, it seems that someone has replaced the RCBO with an MCB and taped two bits of tape in a cross over a socket behind the TV and told the homeowner not to use it.. ho hum.
So even before I get the test kit out, I go and inspect the socket in question, I unscrew it from the wall and notice there is quite a bit of corrosion in the box, but other than that, nothing looks too much amiss (apart from a mising gromet), I go to screw the socket back for the time being, as I do so I feel a tingling in my hand... I immediatly pull the socket forward again and try and work out what i've touched, not finding anything I go to push it back again, eyeballing what I'm doing closely to see if I can work out what I felt. I'm supprised to notice that as I do so, the screw seems to draw small arcs as it touches the backbox lugs. I'm now sure that there is something seriously wrong here, and I bang the 3 neon socket tester in for a clue... and it indicates Live/Neutral reversal.
Anyone like to take a guess?
