gutering keeps comeing undone
23 Apr 2011
Derbyshire
hi, we had new fascias and guttering 3 yrs ago, must be the 3rd time now ive had to clip this guttering back on, it has a large drop at the front of the property,
1st - time i pushed it back in
2nd time i wrapped water proof tape around joint (inside) to make tighter fit - this worked but in the heavy window its dropped a bit (not fallen off)
3rd suggestion - was going to put a screw at the back of the top bits of drain pipe - so it cant drop - didnt really want do see a screw
anyone help please, its pretty high and annoying - only happens
on x1 - other 3 are fine for some reason
Do you mean the downpipe keeps slipping down? If that's the problem then the clamps holding it to the wall aren't doing their job, either they're slack or there aren't enough of them. The joints shouldn't be taking any load and you're right to avoid putting screws in them.
sorry i mean the bit were it pushes in to the bit that runs along the top - as it comes down the side of the property at a 90 degree bend - just at the top
thanks
Fair enough. Normally they're just a snug fit but if one keeps coming loose you could try a solvent weld product to bond the joint. Ideally you could test it on a couple of scraps of the same plastic to make sure it will work but it should be ok on most kinds of rainwater product. There are a few brands but here is an example..
http://www.screwfix.com/p/floplast-sc250-solvent-cement-250ml/14295
The bonded surfaces need to be clean so rubbing them down with a bit of scotchbrite or other fine abrasive before bonding might help.
The off-set between the rainwater pipe and gutter?
Put a screw in it! or make up another off-set which is tighter.
