GW Micron 50
26 Jun 2004
London
I went to one tonight which seems to be inoperative as a result of a high resistance NTC. It measures 44 k when at about 28 ° C.
What should it be? Applying 10 K across the connections brings the boiler on !
The NTC is screwed in with a clamping male screw. Can anyone describe with dimensions what the NTC element actually looks like?
Between 14k - 2.5kOhms. according to the MI's Tony
No dimensions in there but it does say its a phial
Sounds like you are describimg the o/heat cut out the thermister is just pushed into a phial pockeT a long copper sensor in two halves on the older one the new is one piece. As the boiler has not got pump over run tend to find a few that have overheated and need to be reset.
It's 10k at 20celsius
