Hairline crack in Traditional old radiators
2 Jan 2008
Devon
Ref: hairline crack in Traditional old radiators
Look at this picture: don't really need to say much more.
http://www.scarlet-design.co.uk/myfiles/Private/Rads_3675.jpg
Any experienced Problem-Solvers out there who've ideas on repairs? Remeberr: this is made from Cast Iron!
(you'll see someone's had a go at welding (I don't know whom, we inherited this unit with the new house, but now we need it)
Cheers
SP
This should be quite an easy repair.The thing with cast iron, it has to be heated (oxy acetylene) till it's practicaly glowing, then either stick welded,or maybe migged. Looks like it wasn't heated before welding.
why not just take out the section thats leaking youll have a shorter rad but easier than trying to weld cast
Oh, now that's helpful. Already found somebody in Totnes who can do it!
Many thanks
Carey
Hi sp
The fernox is usually OK on low water content systems but as you have cast iron radiators it would not be classed as low water content, Where as oxypic is suitable for larger systems.
Cheers
spraggo
Remove the section for a neat job.
Or for a cheap fix use Milliput. It can be sanded down if you wanted and painted. Available in most decent merchants.
