- Joined
- 11 Jul 2009
- Messages
- 4
- Reaction score
- 0
- Country
I have no idea how my downstairs hallway light is supposed to be wired. I hope someone can help.
Downstairs is a double switch which is supposed to control two downstairs lights (which work simultainiously with each other) with one switch, and then the upstairs landing light with the other switch.
The upstairs landing light of course having its own single switch as well.
The upstaris lght is wired as follows, from the 3 core cable yellow goes to the top connector labelled (1), the blue cable goes to the bottom connector labelled (1), and the red cable runs to the bottom connector labelled (2).
The two red wires from the 2 core cable run with 1 to the bottom connector (1) and one to the bottom conector (2).
I hope this makes sense, i'm not the most experienced if you can't tell.
Does anyone know how I should wire the bottom double swith so that it all works correctly? The double light switch is a modern one, with two sets of L1, L2 and Com terminals.
Your help will be greatly appreciated.
