Halogen outdoor floodlight LED replacement?
19 Dec 2019
I have a set of lights painting in each direction with built in PIR to set them off.
They use a Sylvania Hispot 95 Halogen 75watt bulb.
Does anyone know if I can get an LED bulb equivalent that can replace these ones?
Many thanks.
As said Advert for a 10 Watt LED flood light not hard to find, only question is will the built in PIR work with the LED.
I have converted my lights to smart so I can turn on in the car to see way up the drive, and removed the PIR, however although found a colour changing smart bulb, at around £27 each in your case likely cheaper to change the whole lamp.
GU10 spots are cheap but the E27 seem expensive as a smart stop light.
Thanks for the recommendations guys.
I read about LED's sometimes having issues with PIRs.
Could this cause any problems?
I have a normal 60 watt LED equivilant bulb in my front lantern light with PIR and that works fine.
