I am having problems with my Halstead boiler and wonder if anyone can give me some advice.
Initially my boiler would not respond to being turned off at the boiler clock, and continued to provide heating unless turned off at the mains.
On starting the boiler at the mains with the clock switch set to off the boiler starts up and provides CH. The boiler does not seem to run long before it stops, radiators are warm but not hot. Boiler then continues to come on and off even if you turn off or on or timed on the clock or if the stat is off or on or the link is in for "no room stat".
I have 240v across the live and room stat and it turns to 0v when stat turned off. I have also swapped the thermistors so the DHW and CH ones are swapped and this makes no difference. The DHW is fine.
I have also moved the "no Clock jumper on the PCB but this makes no odds. The fan venturi and flow Diaphram are ok.
I know the boiler has a frost protection on it and wonder if this is any way causing the prob? Please help
