Halstead gold combi no power ?
31 Dec 2006
Nottinghamshire
Had a quick look at neighbours boiler just now,tools at work.checked mains fuses ok, fuse spur replaced 13 amp with correct 3 amp and even replaced internal fuse on pcb.before i go back with multimeter tomorrow,anybody aware of any obvious faults on this boiler ?
Which Gold - Finest or Quattro?
Tried pressing in the overheat stat underneath the boiler.
You an RGI?
I'm not sure of the model, it's the one where the on /off dial on the right hand side also incorporates a reset by turning it , like baxi 105.
Yes im afraid i am corgi registered too, mainly boiler polishing.
sarahs dad said:
I'm not sure of the model, it's the one where the on /off switch on the right hand side also incorporates a reset by turning it .
is it doing anything matey? :)
Nothing at all, No noen lit when fuse spur and boiler turned on have checked all external electrics visually and fuses.Im asuming neon should be lit when powered up.air pressure switch or pcb spring to mind but i'll just have to check it tomorrow with multimeter.
With it being a neighbour he'll expect something for nothing.
Thanks for that, it is the Halstead platinum model and i'm gonna have to give it the full monty tomorrow. Thanks again for your help chaps....
