- Joined
- 17 Mar 2022
- Messages
- 93
- Reaction score
- 12
- Country
Hi - I'd like to ask a bit of advice about hanging plasterboard, as I've heard conflicting things. I'm renovating a house that's about 130 years old. I've built an extension and taken down and added some internal walls. For the new stud walls I've sheathed them in OSB withacoustic insulation inside the cavity.
There are three kinds of walls I'd like to ask about: old external walls, old internal walls, and new external walls.
1. The old external walls are a skin of brick on the inside and mortar and flint on the outside. The old plaster/render was all blown inside and I've taken it off. Can I SBR then dot and dab plasterboard onto the brick, or is that a problem since they aren't insulated cavity walls? There's one upastairs corridor where width is at a premium; because the new sloped roof outside meets the external wall there, only the top foot or so is directly expised to the outside, if you see what I mean -- I'm particularly concerned about what to do here.
2. The old internal walls are also brick, and I've removed the plaster/render where it was blown. Is dot and dab ok here, since the boards won't be covering a cold wall? They're extremely uneven, so battening would be a real pain.
3. The new extension walls are thermalite blocks with an insulation-filled cavity. I've battened some walls out where pipe work needs to be accommodated. Is ordinary plasterboard ok on these battens? And is dot and dab ok on the remaining walls?
Thanks in advance for any help!
