my shower keeps triping after 5mins. so after 4 years of not using it, i have decided to fix it.
i have an older push-button Wylex fuse box and the MCB has a push button on it. the shower MCB is 30A
can i replace it with a newer style flip switch MCB from b&q of do i need to source an older style push button MCB?
also i have seen the wire going out of the box took the shower apart to see if it went into the shower. i think it is at least 6mm2 cable maybe more. but i have little knowlege. just looked at pictures of cable online.
it is the flat style of cable and looks huge next to the other wires . it measures exactly 10mm wide on the flat surface. does that mean the cable is rated 10mm2?
cheers
cheers
