We have a well with a centrifugal pump in the pump house (small shed) with the control gear including a UV system. Its all connected together with 25mm HDPE pipe and fittings. I have just replaced the pump and several of the fittings are leaking especially once it gets up to pumping pressure (about 50 psi). I cant see why as the sealing is done with 'O' rings and they look and feel OK as does the rest of the fitting. Tightening them more doesn't help much.
Any ideas? Thanks
Peter
Any ideas? Thanks
Peter
