unless you get a high temp model like the Daikin Altherma you'll prob need to almost double the size of your radiators. What fuel are you using now?
Why do you think a heat pump will operate with a standard heating system?
Are you suggesting that you think by having a heat pump pushing out water into the system at 40ºC and the oil boiler doing the same this will result in an 80ºC c/h temp? The result of the above will be a c/h temp of 40ºC, adding a second heat source will cause it to heat up faster, but not get any hotter.
I have an oil system costing £50 a week in the cold spell ,which is to much for a 3 bedroom 9" solid wall.I would like to insulate outside walls but my
wife does not want the mess.
you'd get more heat and value for money by burning £20 notes on an open fire.![]()
