heating a room without CH pipes
t78
29 Nov 2008
Essex
hi,
I live upstairs in a converted semi and have a small lobby at the bottom of the stairs by the front door. this area gets quite cold as there is no heating down there (my CH system is all upstairs).
I thought about fitting a electric heater but are there any other options?
thanks.
the point I was trying to make above was that my CH pipes are not availble where I want the heater/rad to go; they are somewhere under the floor of the room above.
it seems like alot of effort to divert them downstairs just to heat a single radiator?
They can be extended downstairs to a rad there.
Be aware that the cost of heating that area will be about 5-10% of your gas bill all for a few seconds while you walk through there.
Is it shared with downstairs? It would possibly be easier connected to their system.
Tony
You'd have to chase a cable down there if you want to put a permanent fixed electric heater down there.
my electric box is by the front door so I can get a new wire from there.
would an electric heater be hideously uneconomical?
Sorry to be vague, but it depends on the heat loss for the area and mainly the ventilation losses. If it's a really draughty spot you could need something like a 1kW panel heater. If it's not too bad a 500W will do the job.
Dimplex do some decent ones that I use on electric heating applications (think it's a PLX from memory) and you can get them with timeclocks fitted so you can program when they run.
Sorry if I sound negative, but as you only pass through this place for a few seconds and always dressed for the outside ambient temperature then I am surprised why you are so keen to pay about £200 to have a heater fitted and about £80-£160 a year to keep it warm.
Tony
