Heating Mystery
3 Oct 2009
Cambridgeshire
My central heating is working when the timer and the thermostat show it to be off. The hot water is heating and the timer control panel shows no central heating at this time - yet the radiators are hot. Cannot turn the heating off as it thinks it is not on!!
Ideas?
I have a Baxi combination boiler and radiators controlled via a honeywell timer - is that sufficient info?
Woops - demonstrating my ignorance here - I mean condensing not combi!! Show's that I need help!!
Yes, there is a cylinder in the airing cupboard ........
KEV :wink:
Faulty motorised valve stuck open and microswitch inside made giving power to boiler and pump even with clock and stats set to off
Thanks guys
Could it be anything else though? The switch was replaced only a couple of months ago so would another one get stuck??
What is the make/model of the 3port valve.
On some the arm bends.
