Heating wont work but water will ?? HELP
8 Dec 2007
As title, i have a ideal classic boiler with honeywell t6360 thermostat and a honeywell ST699 controller, when i set the heating to constant it doesn't come on, as it doesn't when set to timed, but the light does ?, if i switch the hot water on however then it comes on fine no problems ?
hope someone can help
oh and im new here so hello :-)
I have a very simliar problem with Ideal Istor. If I set the programmer to auto and put heating on - then I get a small click on programmer but not the normal click but the heating does not come on.
If I set the programmer to auto and put heating and hot water on - then i get normal click and the hot water comes on and when that finishes the heating comes on.
You mentioned motorised valve - is this the diverter valvle?
is there a way of testing the thermostat ?, when turning the knoball i get is a click around 15 ?, is this normal
mine clicks if i go below 18 and the pump wont work, it has to be over 18 to circulate the water through the downstairs rads
As the thermostat works on temperature, there is no normal. It appears to be 15 C in your house which is not bad for no heating. If you can be there all day wearing a shirt or maybe a wooly, your stat probably works
ok, well i still cant get the heating to come on ?, any ideas
ps i havce tried a new controller and that didnt cure it
Professionals check a system with an electrical test meter !
Not by blindly changing parts!
Tony
Chances are it's the motorised valve.
Agile said that, so why don't you believe him?
:roll:
i didnt say i didnt believe him, he just wrote it with a ?, & i thought he was asking if my system had a motorised valve ?? so i wasnt sure (im no plumber so would not have a clue, hence why im asking here)
Tony
whose blindly changing parts ?, when helping a neighbour change kitchens i was given there old unit (exactly same as mine) so i tried that on, it did after all just clip on and only took me 1 minute to change it so wasnt a massive job after all
Ps thanks to everyone for there help
anyone ?, is there a way of overriding the motorised valve, i would change the valve but its right behind the boiler and no accessible at all !!!
cheers
