Hi
Recently had an issue with my heatslave 12/18 where it couldn’t come out of lockout. It turned out to be a photo sensor that had deteriorated and a burner nozzle which was completely coked up.
since then the hot water supply has been changeable with showers suddenly cooling off to cold mains temperatures - I put this down to a couple of especially cold mornings however at the weekend when using the hot water tap the pipes started shaking violently and water spluttered out.
Now the hot water tap works but with about half the pressure it used to have. Tap is very light compared to the old water tap and the temperature fluctuates quite a bit.
I’ve read that the nozzle may have been changed for a smaller one. But that’s as far as I’ve got. I’m not sure it explains the really low hot water pressure.
many thanks
many thanks
