Hi, hoping someone can help. Heatslave oil fired boiler driving me insane.
Locked out - checked the water pressure gauge which was somehow through the roof at 4bar. Released the pressure. Won't fire up, keep getting lockout. Trying to bleed the system at the pump - just get never ending air bubbles, have tried 100 times for the 16 or seconds it runs before locking out again (holding lockout button will not result in it running indefinitely).
Went outside to check the lines - it's a single line feed from tank with a tigerloop. Oil drips from a low height connection before tigerloop but at the base of the tigerloop itself (input) cracked that off, no oil comes out. No oil comes out of any of the tigerloop connections at all.
Tried using a vacuum cleaner to pull the oil through the tigerloop to the outlet, thought I'd done it - still same result though - endless air bubbles from the pump when bleeding.
What are you supposed to do with these things? Any help greatly appreciated. Thanks.
