Ok well not a Plummer but a girl who doesn't want duped when she calls out plumber!
Problem
The hot water taps upstairs sputter out then stops to a trickle. I turned on the wash basin (higher than bath) then when bath tap on (trickling) the washbasin tap stops. The water trickling out is hot
Heating working fine. I have a cold water feed into the boiler. The cold water tank looks fine and full went up and checked working fine.
2 days ago I had a nice full pressure warm bath so something is away very fast overnight. Downstairs taps fine although pressure could be slightly reduced, not sure.
I am guessing air lock or something blocking...but why the change so fast over night?
Could it be some sort of valve thing I know it works on heights and pressure and gravity system?
Sorry, I don't know the make of the boiler. Was wondering if the tank is in my chimney and how do I look at it?
I just want some ideas a normal Plummer would look at so I am an informed customer.
Thank you all
xx
Problem
Thank you all
xx
