Help in choosing an outside security light/movement sensor
11 Oct 2010
Buckinghamshire
I've had a light with sensor above the back door for many years now, but the sensor has more or less had it. Partly because I guess of what was available at the time the light is very dim, and I certainly want it brighter. I've got about 25 metres of back garden, but I recognise that I don't want to floodlight the area like a football pitch and upset the neighbours.
Just a reliable security light that will give reasonable illumination 180 round and motion sensor. My daughter's been looking at options and products but we've seen so many contradictory reviews that it's difficult to make a decision.
She's come to thinking that LED 80W or 100W would be the best fit? Anyone's thoughts and suggested products would be brilliant. Would separate light and sensor be best in case of sensor failure meaning a new light too?
The one I'm replacing has lasted 10 years so I'd rather pay a bit more for a reliable product. Recommendations very very welcome.
Thanks.
Can you even get a 100 watt LED? One or two 10 watt or 20 watt LED floodlights would surely be enough.
ive not been too impressed with the built in sensors on the led fittings and there adjustibility is limited, a remote sensor means you can opt for a better quality sensor which has a wider range and more movement to suit your needs
As said steinel is a good brand
I've had good experiences with the Mr. Beams products. Not wired-up, so may not be what you want, but a good light / sensor combo in a neat little package.
I have installed a number of these over recent years, they are no LED but you can fit eco halogen tubes to them.
The light has tilt and pan as does the sensor which detects at 200 degrees. Very reliable unit.
The words "eco" and "halogen tubes" do not deserve to be in the same sentence.
No filament type lamp is economical.
