First post, so be gentle please.
System: 19 yr old Open vented fully pumped with mid position diverter valve.
Boiler: Potterton Flamingo
3 port valve
3 speed pump
6 radiators
Installation is in a bungallow with most pipework dropping from the attic.
Boiler location: Garage
Each time I have had to drain the system for whatever the reason at the time ( Replacing leaking valves mainly) it has been a hell of a job purging the air from the system.
As a consequence I now use mains pressure to flush through and bleed the system.
To do this I have fitted a gate valve either side of the cistern feed to isolate the cistern.
To the outer sides of each gate valve I have fitted an in-line tap.
To the tap on the pump side of the feed, I open it and put in the mains water (protect/anti syphon type tap and hose connection so as not to contaminate water).
To the tap on the other side I connect a hose and open out to the drains.
I shut all the radiators down then opening and purging one at a time. The circuit through the water cylinder I treat a another radiator using its gate valve to shut off as required. This eventually purges all the air with just a tad left to vent from the radiator bleed valves themselves.
What I cannot undertstand is that I can only seem to do this in ONE direction. It flows from the boiler towards the pump and it will not flow in the opposite direction.
I have have read the information at the top of the forum and at one point it suggests that there may be some type of Anti-gravity or check valve in the system.
My questions are really just to gain a better understanding of what is happening and which are as follows:
1) Is it normal for the system to flow in one direction only, or do I have a fault?
2) If it does only flow one way, will there be a check/one way valve?
3) If there is a such a valve where would this likely be located?
4) The info at the top of the forum suggest that when I use this method for a system flush that it may be advisable to flush in both directions. Is this considered necessary?
5) If considered necessary how do you bypass the one-way valve?
Malc
3 port valve
3 speed pump
6 radiators
Malc
