Help me with my boiler?
5 Sep 2009
Hartlepool
hello,
ive had my boiler for 2 and a half years now, and all of a sudden it has started to flash a red light and doesnt let hto water out when i need it.. has anyone got a solution to my problem? how do i fix my boiler?
it also says benchmark, so it may be that but im not sure because it also says heat line..
i do not mean to be rude, but your comments show you have little knowledge of boilers, so be careful, if you have the manufcturers instructions you need to look for "reset button" or "reset system" usually a button or switch on the front somewhere, sometimes there is a dial switch with "off" "reset" "on" move switch to reset then back to on it may work, some reset buttons are the red light itself so try to push that in, if it wont reset you will need to get an engineer in to look at it, just a thought but do you def have gas, it wouldn't be the first time i went to one where the gas was off due to credit meter running out or gas being switched off
haha dont worry about the rudeness to be honest i havent got much knowledge on boilers haha.. and thanks for the advice ill try it out and its a comby boiler.
