Hi there,
I was hoping someone out there may be able to help
I have a Valliant Combi in good Boiler, reasonably old, but works a treat until today.
Hot water is working fine...
The central heating however wont come on - now, its operated through a timer and a downstairs thermostat. I have checked the glass fuses on the boiler everything is fine and as I say, it fires up when we turn the hot taps on.
The timer however, although I can hear the timing mechanism the small light which shows when the boiler on is not working. Ive tried it on all settings (twice,once,24hr) and still nothing.
The timer is an EMT 2 with the British Gas logo on, and was fitted about 5 years ago..
My gut feeling is that something in the timer has gone. The thermostat seems ok, Ive checked the wiring and that was only replaced about 18 months ago.
Does anyone have any knowledge before |I open the timer up if it has its own fuse and if this is the likely cause or should I be looking for something else.
Kind Regards
Duncan
Kind Regards
Duncan
