Don't selectively (mis)quote me, please.As said earlier, on latch, auxillary switch does not operate. That is the case with all valves. There might be an odd one that rule does not apply to
A temporary solution would be latch open the UF heating valve and let another zone fire the boiler and boiler pump
I am suggesting to OP than the manual opening is allowing the valve motor to then operate as designed due to a mechanical (or possibly intermittent electrical) issue. Thus valve microswitch makes it work --- until nest time!!!
