Help - New Boiler - Possible Cowboy!
The stacks non-compliant as well...its not high enough.
And even worse......its an Ideal boiler :(
You're gonna bang your head a treat when you're sat on the loo too.
Nice dangling cable as well!
The others spotted the uphill condensate drain which willo be noice and frozen b say mid January (I nreckon).
AND ITS AN ISAR! :shock: :o
Has he left the filling loop connected behind the plasterboard, and is that hole an access for opening and closing it?
Flue terminal clearances look a bit suspect as well, 200mm from eaves & 300mm from internal corner, I know you can reduce these down to 25mm but you're only allowed 1 reduction.
is there a bath or shower in the room? i may be wrong but isn't the boiler located in zone 2 and not zone 3, BS.7671 as required by the M.I
edit. nevermind i just looked it up and it's in the right place if that's a washbasin in the pic.
