Rather not use heat inside an existing house if i have a choiceLagerkhan said:why don't you want to solder![]()
clf-gas said:BS669 is for hoses for nat gas.
There is no BS for lpg hoses within BS669.
Correct red is used to denote LPG usage.
So which bit is wrong Stan.
You need to read carefully my old fruit then get back to me again.clf-gas said:BS669 is for hoses for nat gas.
pannierstan said:You need to read carefully my old fruit then get back to me again.clf-gas said:BS669 is for hoses for nat gas.
I might be getting old but I trained engineers for ACS for 5 years and that bit aint changed.
Stan
giblets said:From BES's web site:
4.LPG hoses. There is no British Standard which refers to LPG cooker hoses. They are, however, identical to the hoses specified under 1, 2, and 3 above, except that the sealing thread within the hose is nitrile and that the cover is nitrile or neoprene. LPG hoses are identified by a red band or stripe.
pannierstan said:Steady on Costy old boy we know, but we have now moved on to arguing amongst our selves for a bit.
You just hang on we will be back with you in a sec![]()
The clouds of time have not been kind to me clf
Stan
sambotc said:Regardless if you are using a kit from BES or not, you still have to be a corgi registered installer to fit it!
At what point have i mis-understood you?
Surely if you knew the answer you would be more than happy to answer it?![]()
