Symptoms- I hadn't really thought you could buy a thickness planer for diy prices but having looked at ebay they seem affordable. Maybe thats the way forward instead of sanding afterwards. Can you tell me whether the finish from a planer will be up to the job or would I need to fine sand as well if I wanted a really smooth finish? Im also assuming that if I plane a mill off the top then the floor will be all the same level (ie the t&g will all be the same height from the base- probably a stupid question)
Maybe to get the really smooth even finish I need, I should use a thickness planer and a fine sander. Any advice would be very welcome
