This is the hinge I have bought
http://www.toolstation.com/shop/Iro...re+Escape+Hinge+300+x+17mm/d170/sd3183/p11278
The bit that attaches to the frame fits snug into the side of the frame and all the holes line up ok.
I have attached the sash to the other bar using the first screw nearest the hinge pivot point only but am struggling to adjust it so the window closes. With an inch to go, the window gets stuck.
where should the bar that attaches to the sash be placed? (ignoring any holes from the previous hinge)
There is about 1cm of adjustment on the first screw location - If i pull the window closer to the hinge pivot it starts to hide the triangular locator - if I push it away from the pivot - the handle fouls the fixed window.
