    Dismiss Notice
Help - unsure about what to use.. painting new metal railing
Discussion in 'Decorating and Painting' started by dand99, 3 Aug 2011.
  1. dand99
    dand99
    3 Aug 2011
    10
    Thanks Received:
    Country:
    I need to paint a balcony railing that's a real mix of metals (all new and unpainted).
    1. Cold-galvanised metal profiles
    2. Hot- galvanised metal strips (a little bit of chips in the galv layer at edges) - these have some flexibility to move (over a 500 mm length they can bend a couple of mm in the middle)
    3. Thin iron bars
    4. Galvanised nuts and bolts
    5. Welds - unfortunately, in difficult places and not neat
    As soon as I complete the welding (not major) on a portion, I spray cold glav paint on the iron bars and on the welds.
    So - my dilemma.... do I assume that the zinc paint is as good as galv and use Hammerite direct to galv ?
    Should I prime first with a non-iron primer, then Hammerite direct to galv ?
    Should I prepare the surface another way first ?
    Or use another type of paint ?
    Am looking to delay the onset of rust as much as I can....
    Grateful for any input -
    D.
  2. Sponsored Links
  3. Alarm
    Alarm
    18 Oct 2010
    8,965
    Thanks Received:
    532
    London
    Country:
    Red Oxide over the zinc, then the Hammerite.
  4. misterhelpful
    misterhelpful
    19 Feb 2011
    3,210
    Thanks Received:
    525
    Ohio (formerly Mid Glamorgan)
    Country:
    Zinc phosphate primer and a good quality exterior grade gloss is preferable to Hammerite which dries/skins far too quickly (especially at this time of year) in my opinion. Red oxide primer does a similar job to the zinc phosphate.
  5. TheDec
    TheDec
    12 Aug 2010
    2,264
    Thanks Received:
    373
    Glamorgan
    Country:
    You say these railings are new and unpainted, if this is correct have the galvanised sections been treated with a mordant solution, if not no paint system will bond.
    Dec
  6. Robbie uk
    Robbie uk
    9 Apr 2007
    2,059
    Thanks Received:
    267
    Cheshire
    Country:
    Or use a Calcium Plumbate primer, either way the new Galv will need doing first.
    • Thanks Thanks x 1
  7. dcdec
    dcdec
    14 Jan 2011
    1,475
    Thanks Received:
    408
    Hampshire
    Country:
    should all be "de-greased" first with brush cleaner.
    Hate hammerite, as Mr H says a good quality exterior gloss such as sikkens xd and the zinc phosphate primer
    and don't skip the u/c
  8. Sponsored Links
  9. dand99
    dand99
    3 Aug 2011
    10
    Thanks Received:
    Country:
    Correct, the railings are new and untreated. That's why I thought of painting with Hammerite for galvanized directly - is that not possible ?
    If I go ahead and paint with a red oxide primer first, do I need to do anything besides clean/degrease ?
    D.
  10. misterhelpful
    misterhelpful
    19 Feb 2011
    3,210
    Thanks Received:
    525
    Country:
    Have you guys got a secret stash of calcium plumbate? As I recall, it was banned shortly after I began painting in the early 90's. :confused:
  11. dcdec
    dcdec
    14 Jan 2011
    1,475
    Thanks Received:
    408
    Hampshire
    Country:
    Hammerite is just yuck for several reasons. Its gloopy and doesn't flow because it starts to set up really quickly. It also goes flat over time. You have to buy cellulose thinners if you want to thin it to aid flow.
    De-grease, prime, undercoat and gloss.
    A paint mitten can be useful for railings, would certainly speed things up.
  12. Nige F
    Nige F
    28 Jun 2005
    21,195
    Thanks Received:
    1,740
    Country:
    Calcium plumbate - magnet lead paint- Walpamur wall paint - tub of snowcem powder - and a lot of Brolacs :mrgreen: Got `em all
    • Thanks Thanks x 1
  13. Robbie uk
    Robbie uk
    9 Apr 2007
    2,059
    Thanks Received:
    267
    Cheshire
    Country:
    Always come in handy !!!!!! Keep in the back of the shed !! ;)
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
